Working with Workbook Internal Data Table Editor Layout
This data table editor accessed in a workbook allows you to quickly connect to any data source and combine data from multiple sources so you can visualize all your data in a single visualization.
Connecting to data environments is easy with pre-built connectors to a wide variety of sources right out of the box.
However, to get the most of these data and produce effective visualizations, they may need to be:
  • Integrated with other data sources or files to produce a data with more sense.
  • Transformed for normalization and aggregation.
The Workbook Internal Data Table Editor layout is displayed as below, where in this example, there are joined data sources:
Workbook Internal Data Table Editor Sections and Definitions
Section Description
1
Back
Exit the Workbook Data Table Editor view and go to the Open Workbook in Design Mode
view.
2
Data Table
List of data tables. Can be rearranged.
3
Toolbar
After the data is successfully retrieved, these options on the Workbook Data Table
Editor
layout allows:
4
Search Columns
Allows searching of columns on the Data Sources Preview.
5
Data Preview
Execute the queries to return and display preview of the data table you are creating.
NOTE: the maximum number of rows displayed in the Data Preview is 1000.
6
Move to Data Library
Move the data table to the Data Library.
7
Add Data Table or Select Data Template
Add data table or select a data table template.
8
Data Table Parameters
Add or manage data table parameters.
9
Data Table Settings
Definition of the name of the selected data table, description, and the auto refresh period (in seconds).
NOTE:  Auto Refresh is disabled for data table in data store and connectors that only work on uploaded data or Upload File load type. These include the following connectors:
  • File Data
  • Text Entry
  • SVG
  • MS Excel
  • Text
  • JSON
  • XML
Also allows the following:
10
Group and Sort Columns
When the Column Order is set to Sorted, the columns are grouped by type (Text, Date/Time,
then Numeric) and sorted alphabetically.
11
Data Sources
One or more data sources that can be connected directly with data retrieved on the fly as it is required. Can be rearranged.
12
Join/Union All Definition
Allows definition of a join or union all of multiple data sources.
13
Duplicate Data Source
Allows you to create a duplicate data source
14
Add Data Source
Allows you to add data sources from the available data connectors.
15
Connector Settings
Displays the connector settings of the data source and allows for limiting the amount of data to be returned.
16
Preview Selected Data Source
Preview the selected data source on the Data Preview panel.
17
Refresh Preview
Refresh the data sources preview.
18
Save Data Table
Save the data table definition and go to the Open Workbook in Design Mode view.
19
Row Limits Settings
Allows setting of the row limit of data sources.
20
Collapse Data Preview
Collapse the Data Preview pane. Click  to expand the Data Preview pane.
NOTE: Most of these sections are also available in the Data Table Editor in the Data Library page.
Clicking Calculated Columns   displays the New Column list box.
Option Description
Add Auto Key
Allows creation of an auto key for the data schema on the Data Sources Preview.
Add New Calculated Column
Allows creation of a calculated column from the existing columns in the data table.
Add New Ranking Column
Allows creation of a new numeric column based on the ranking of columns in your data.
Add New Time Bucket Column
Allows creation of time buckets (categorical time analysis).
Add New Numeric Bucket Column
Allows creation of Identity, Sign, Manual, Equal Density, and Equal Distance columns.
Add New Text Grouping
Allows creation of a grouping based on source text column.
Clicking Debug   displays the Debug pane.
Section Description
1
Data Table Id
Id of the data table. Can be used for parsing of server logs.
2
Data table is used on dashboard(s)
List of dashboards where the data table is used. If a data table is not used, it
can be deleted.
3
Data Log
Logs of the last query
IMPORTANT: Data log is supported in Kx kdb+, JDBC, SPARQL, Python connectors, and Python transform.
4
Data Log Details
Details of the data log which includes the data source name, response time, and duration (ms).
5
Parameters on the data table.
Clicking Transform Settings   displays the Transform Settings pane.
Section Description
Transform Settings
Allows you to perform the following:
Clicking Columns    displays the Columns Settings pane.
Section Description
Column Settings
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
