Specifying the Set of Columns To Be Included When Exporting Raw Data
The raw data of visualization can be exported and copied to a clipboard for future use in another application.
In the Workbook Data Table Editor, you can specify the set of columns that will be included when exporting raw data.
- On the Export Raw Data section of the Data Table Settings pane, select one of the Include Columns options:
Property Description All
All the data from the source data table is exported, and not just the actively displayed nodes within a visualization. This is the default setting.
Exclude Calculated
Calculated columns are excluded when exporting raw data.
Custom
Only selected columns are included when exporting raw data.
When set to Custom, a searchable checkbox list is displayed populated with column names. For example:
Select the checkboxes of the columns that will be exported.
- Click the Save
button.
