Prep Data Column Operations
When preparing data in Data Prep Studio, you can perform various operations not only for a single column but also for multiple columns of either the same data type or different data types. The availability of these operations depends on the data types of the columns selected. This section lists and defines the operations that you can perform when working with columns in Data Prep Studio.
Copy
Operation
Data Type
Copy/Copy With Headers
text, date/time, numeric
Copies column values only or column values with headers to the clipboard.
Create Table from Selection
Creates a new table based on the columns and rows highlighted in an existing table.
Filter
Operation
Data Type
Define Filter
text, number, date/time
Launches the Define Filter dialog to create a new filter to apply to the table.
Discard All Filters
Removes all filters applied to the table
Sort
Operation
Data Type
Sort Selected Columns
Sorts the column values in descending order
Define Sort
Launches the Sort dialog to define a new sort order
Column
Operation
Data Type
New Formula Column
Adds a new formula column to the table
New Constant-value Column
Adds a new constant-value column to the table
New Lookup Column
Adds a new lookup column to the table
New Row Number Column
Adds a new row-number column to the table
New Runtime Parameter Column
Adds a new runtime parameter column to the table
Add or Remove Metadata Columns
Adds metadata columns to your table
Rename...
Changes the column name.
Duplicate
Creates a copy of a column.
Hide
Hides the selected column
Delete
Removes the selected column from the table.
Show Hidden Column
(Displays only when a hidden column exists in a table) Shows a list of hidden columns. Selecting a column from this list displays it in the table once more.
Alignment
Operation
Data Type
Left
Aligns all values to the left of the column
Center
Aligns all values at the center of the column
Right
Aligns all values to the right of the column
Case
Operation
Data Type
Make Proper Case
text
Converts to uppercase the first letter of each word in a string.
Make Lower Case
text
Converts all uppercase letters in a string to lowercase letters.
Make Upper Case
text
Converts a string to all uppercase letters.
Clean
Operation
Data Type
Remove Leading & Trailing Spaces
text
Trims all leading and trailing spaces from a string.
Remove Consecutive Spaces
text
Trims to a single space any sequence of two or more consecutive spaces within a string. It also removes any leading or trailing spaces from the string.
Remove Specified Characters
text
Removes a sequence of characters from the values of the column you apply this operation to.
Remove Non Alphanumeric Characters
text
Removes all characters that are not numbers (0-9) or letters of the alphabet (A-Z/a-z) from a column value.
Remove Numeric Characters
text
Removes all numbers from a column value.
Remove Alpha Characters
text
Removes all alpha characters from a column
Convert
Operation
Data Type
Text to Number
text
Converts a text string to a numeric field.
Advanced Text to Number
text
Converts text fields with the values “X B,” “X M,” and “X K,” where “X” is any number, into “X,000,000,000,” “X,000,000,” and “X,000,” respectively.
Text to Date/Time
text
Converts a string to a date/time.
The date format will be: MM/DD/YYYY
HH:MM:SS to Number of Seconds
date/time
Converts a text string containing time information (in HH:MM:SS format) to number of seconds.
Date/Time to Text
date/time
Converts a date/time value to text.
Date/Time to Number
date/time
Converts a date/time value to number.
Number to Text
number
Converts a numeric field to text.
Number to Date/Time
number
Extract
Operation
Data Type
Starting from Left...
text
Extracts n number of characters from the beginning of a string.
Starting from Right...
text
Extracts n number of characters from the end of a string.
Using Position & Length
text
Extracts n number of characters starting from a position you specify.
Between Start & End Strings
text
Extracts n number of characters starting from a start and end position indicated by a sequence of characters.
Line of a Text Block by Line Number
text
Extracts a line from a text block based on the number of the line in the block.
Line of a Text Block by Search Term
text
Extracts a line from a text block based on a given search term.
Replace
Operation
Data Type
Ditto
text
Replace empty cells with the value of the first non-empty cell above it.
Nulls...
text
Replace  null values with one more characters.
Blank Values...
text
Replace  blank values with one more characters.
Using Find and Replace
text
Substitute a fixed sequence of characters with a different one.
Using Position and Length
text
Substitute a number of characters with a different set of characters starting from a set position.
Split
Operation
Data Type
Into Parts from Left...
text
Starts from the left and splits a column into two more columns, depending on a separator you define. The separator may be a single character or a substring.
Into Parts from Right...
text
Starts from the right and splits a column into two more columns, depending on a separator you define. The separator may be a single character or a substring.
Names into Parts
text
Splits the value of a single name column into it's component name parts:
  • Prefix
  • First Name
  • Middle Name
  • Last Name
  • Last Name
  • Suffix
Addresses into Parts
text
Splits the value of a single address column into its component address or postal parts.
When you apply this transformation, Prep Data will ask you which of the following name components are available:
  • City
  • State
  • Postal Code
Date/Time into Parts
date/time
Splits a date/time field into two or columns according to the date/time components you select.
Date Time into ISO 8601 Parts
date/time
Splits a date/time field into two or columns according to the ISO 8601 date/time components you select.
Date/Time into Fiscal Parts
date/time
Splits a date field into its components fiscal parts.
Statistics
Operation
Data Type
Show Statistics
Displays statistics about a column. Statistics will show you:
  • If your table has enough rows for you to work with
  • If There are nulls or blanks
  • The maximum, minimum, and average length of the values of the column
Create Statistics Snapshot
Allows you to create a new table including statistics of a row or several rows.
Compute
Operation
Data Type
Round with Precision
numeric
Rounds number to a specified number of places to the right (or left) of the decimal point.
Round Up (Ceiling)
numeric
Rounds a number up to the nearest integer.
Round Down (Floor)
numeric
Rounds a number down to the nearest integer.
Round Negative Signs (Abs)
numeric
Returns the absolute value of the value of a column.
Remove Decimals (Int)
numeric
Returns the Integer portion of a number.
Calculator
numeric
Launches the Calculator dialog, which you can use to create a calculated field via a graphical interface
Others
Operation
Data Type
Collapse changes unrelated to this column
Allows you to collapse all items in the Change History list that are unrelated to the selected column.
Column List
Allows you to:
  • Rename a column
  • Change column types
  • Hide/unhide columns
  • Reorder columns
  • Add or edit macros
  • Assign column widths and text alignment
  • Set name casing
  • Apply a selected format to all columns of the same type
Format (date/time)
date/time
Formats date/time columns
Format (numeric)
numeric
Formats numeric columns
Insert Text
text
Inserts a constant text string at a specific location in a text field.
Merge
Allows you to merge two columns into one.
Redact
Allows you to redact the values of a column.
Show Statistics
Macros
Allows you to add or modify macros and apply the same to columns.
Delete Column
Allows you to remove a column from the table.
Multi-column operations
When working on multiple columns, you can perform various operations depending on the data types of the selected columns.
  • The Duplicate Columns and Alignment operations are available for multiple columns regardless of data type.
  • The Extract and Split operations are available for multiple columns containing text and date/time data.
  • The Compute operation is available for multiple columns containing numeric data.
Selecting any of the Extract, Split, and Compute operations launches a corresponding dialog box.
From the dialog box, you can further modify the operation and manage the selected columns by sorting or filtering them.
© 2025 Altair Engineering Inc. All Rights Reserved.
