Names into Parts
Splits the value of a single name column into its component name parts.
When you apply this transformation, Data Prep Studio asks you which of the following name components are available:
Prefix
First Name
Middle Name
Last Name
Last Name
Suffix
Data Prep Studio will do the name split depending on the components you selected on the dialog box.
Input/Output Data Type
Input |
Output |
text |
text |
In the example below, Name is the original column, and the remaining three fields to the right are the result of the name split into First Name, Middle Name, and Last Name.
