Replace Blank Values
A blank value means the corresponding string is empty; there is no value assigned to the field.
Replaces blank column values with some other value you specify.
When you apply this operation, Data Prep Studio first asks you to enter the characters you wish to replace nulls with:
Input/Output Data Type
Input
Output
text
text
In this example, Media is the original column. The Replace Blank Values operation was used to remove the null values and replace with MP3 to produce the resulting values in the column Media - No Blank.
© 2025 Altair Engineering Inc. All Rights Reserved.
