Analyze Part
Use the Analyze Part tool to extract loads from a motion analysis for use in structural (FE) analysis of a part.
This lets you select a part and then configure it in preparation for a FE analysis. Use the satellite icons to view the run status and run history.
Note: Run Part Analysis is not supported in SimSolid (motion loads will use OptiStruct).
Analyze Part can be run without first running a motion analysis.
When you run Analyze Part, a flexible body is implicitly created using the first 10 non-rigid body modes. The motion analysis is then performed.
