- Analyze Motion
Use the Analyze Motion tool to run and review the results of a motion analysis.
- Review Flexible Body Results
Review and animate flexible body results including local deformations, stress, and strain apart from the rigid body results.
- Force Explorer
Use the Force Explorer tool to visualize force and torque vectors in a motion analysis.
- Analyze Part
Use the Analyze Part tool to extract loads from a motion analysis for use in structural (FE) analysis of a part.
- Report
Generate PPT or PDF reports from analysis results. The Report tools are available after you have run an analysis.
- Optimize Part
Use the Optimize Part tool to extract loads from a motion analysis for use in structural optimization of a design space.
- Tracers
Use the Tracers tools to visualize the path of a trace part or trace point during a motion run.
- Proximity
Monitor the distance between two parts during the simulation. The endpoints of the proximity measurement are color coded. Blue means parts have a finite distance, yellow means parts are touching, and red means parts are interfering.
- Topology Explorer
Graphically view and edit model connections. This allows for faster and easier debugging, editing, and understanding of model connections.
- Interference Detection
Detect interferences and conditions of tangency between parts, then view detailed results on where they occur in a motion analysis.
