Show Motion Analysis Results
Use the Show Motion Analysis Results tool to view the results of a motion part analysis in the Analysis Explorer. View and animate results, add callouts, and compare results from different runs.
Prerequisite: Run a motion part analysis.
  1. Click the Show Motion Analysis Results tool on the Analyze Part icon.
    Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
    The Analysis Explorer is displayed.
  2. Select the Run you want to view.
  3. Select a Load Case.
  4. Select the Result Type you want to view.
  5. Use the additional options to animate the result, change what is shown in the modeling view, create callouts, and compare results.
  6. Right-click or press Esc to close the Analysis Explorer and return to the original part.
Animation Toolbar
Use the animation toolbar to play, record, and configure the animation.
Figure 1. Animation Toolbar
Animation Settings
Click to open the Animation Settings.
Play and Record/Stop Recording
Click the button to begin recording the results; the icon changes to red to indicate that it is recording. Click the icon again to stop recording.
Start Animation/Pause Animation
Click the button to start or pause the animation. Use the arrow buttons to jump the first or last frame in the animation.
Move to First/Previous/Next/Last Step
These buttons allow you to step through the animation frame-by-frame. If you hold down the Previous or Next button, it will auto-repeat. If you want to skip frames, use the Increment By feature in the Animation Settings; hold Ctrl to temporarily override this behavior.
Slider
Drag the slider on the toolbar to view a particular point during the analysis; use the arrow keys to move frame-by-frame through the animation.
Current Step
Displays the current time or frame. You can also enter a value to go to the nearest time/frame.
Note: The animation toolbar has Previous and Next buttons with an auto-repeat feature, allowing you to step through the animation frame-by-frame by holding down the button. In addition, the Animation Settings include an option to Reverse Playback.
Tip: If a model has multiple systems, you can choose among a model's systems using the System button in the Animation toolbar.
Animation Settings
Modify the animation settings from the animation toolbar.
Figure 2. Animation Settings
Playback
Select whether to play the animation on a continuous Loop, Once, or Bounce (between forwards and backwards). Select the check box to Reverse Playback.
Display
Set the units for the slider to either Time or Frame.
Increment By
Increase the value in the counter to skip frames during playback. The reset button restores the default value of 1.
Speed
Drag the slider to change the speed of the animation.
Range
Select the Range checkbox to define and starting and ending frame for the animation. This allows you to limit the playback range to just a portion of the animation, making it easier to study behaviors in more detail. You can use the Ctrl key while clicking on the Start or End icons to jump to Range Start and Range End, respectively.
Note: For motion models, you can fit plots for the selected range by using the Ctrl key while double-clicking. Also, the paths of tracers will be trimmed to honor the specified range.
Scale Factor
Enter a custom value to change the scale of the animation. Generally the scale of a displacement is too small to see clearly, so auto scaling is enabled by default.
Recording Settings
The default Auto setting gives you an estimate of the duration of the recording at 30 frames per second. If your video plays back faster than you want, select Custom Duration to change the length of the video; this will adjust the frame rate to try to achieve the specified duration. The Custom Duration has a minimum value of 1 second, and maximum value of 30 seconds.
Show Options
Determine what is made visible in the modeling window when viewing analysis results. You can show or hide the initial shape, loads and supports, deformation, and/or contours.
Option Description Note
Show/Hide Initial Shape Show/hide the initial shape as a reference.
Show/Hide All Loads and Supports Show/hide loads and supports. You can also show only the current loads and supports.
Show/Hide Deformed State Show/hide the deformed shape as a reference.
Show/Hide Contours Show/hide contours.
Options
  • Interpolate during animation: Animate the result contour.
  • Blended contours: Toggle between blended and nonblended contours.
  • Element contour: Show contours based on elements rather than nodes. This option is only available for results types that are based on elements.
  • Vector plot: Display the direction vectors for the displacement result type.
Show/Hide Elements Show/hide the element edges. This icon appears under the view controls in the lower left of the modeling window, but only when the Analysis Explorer is active.
Add Callouts to the Results
Call out and review values for a selected result type at points of interest on your model using the callout icons in the Analysis Explorer.
  1. Select the Show Analysis Results tool on the Analyze icon, if not already active.
  2. To create a callout at a point of interest, click in the Analysis Explorer, select a Result Type, and then click a point on your model. Box-select to see the maximum value in an area.
    Note: The callout value applies to the currently selected run and load case.
  3. To automatically create callouts showing where the minimum and maximum values occur for a result type, select a Result Type, and then click .
    Note: When you select Factor of Safety for the result type, the minimum is shown.
  4. Optional: To display callouts in a table, click in the Analysis Explorer. Each callout is specific to a selected run. In Inspire, it is also specific to the selected load case.
    • Selecting a row in the table also selects the callout in the modeling window.
    • To show or hide a single callout, in the Callouts table, Name column, click .
    • To show or hide all callouts, in the Analysis Explorer, click .
    • To sort the order of a column in the table, click the column header. Or you can click or to select Sort Ascending or Sort Descending.
    • To add or delete columns on the table, right-click a column header, and then select or deselect a property.
  5. Optional: For motion part analysis results, click the Plot button to display time history plots for callouts defined for structural analysis. Changes made to the Result Types option are synchronized with the setting on the Analysis Explorer. Using this option allows you to put multiple plots of mixed types on a single page.
Compare Results
Compare the results of multiple analysis runs in a table. The Compare Results button is located at the bottom of the Analysis Explorer.
For analysis, you can compare results across all runs and load cases for the selected result type. You can also compare result types at a point of interest where you have placed a callout.
View the analysis results in the Analysis Explorer.
  2. Click the Compare Results button located at the bottom of the Analysis Explorer.
    The table for comparing results appears at the bottom of the modeling window.
  3. Select the row to display the results for that run and load case.
    • Double-click a cell in the table to show that result in the modeling window.
    • Click the chevron next to the table title to select a different result type or a callout.
    • Click the chevron on a column header to filter results.
    • Click a column header to sort the column.
    • Right-click a column header to change what result types, run parameters, or callouts are shown in the table.
    • Click the top left corner of the table to copy the contents of all cells. This can then be pasted into Excel.
Additional columns can be added to show additional result types and parameters from the Run Analysis window. The red-blue color bands correspond to the legend in the Analysis Explorer; the width of the band indicates the magnitude of the result. Changes to the upper and lower bound in the Analysis Explorer are automatically reflected in the Compare Analysis Results table.
