Run Analysis on a Part
Use the Run Part Analysis tool to configure various settings for the part to be analyzed.
  1. Click Run Analysis on the Analyze Part icon.
    Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
  2. Select a part to analyze. The Run Part Analysis window appears.
  3. The Name defaults to the name of the part, but you can enter an alternate name in the text entry field.
  4. Change the Element size if desired. Increase the value to obtain coarser results; decrease the value to obtain finer results.
  5. Under Speed/Accuracy, select from the following options:
    • Faster, which uses 1st order elements.
    • More accurate, which uses 2nd order elements.
  6. Under Results, choose which types of outputs you prefer to see. Stress output components will be generated by default.
  7. Optional: Using Mesh Control, you can assign a specific mesh size to different faces on the part.
  8. If at any time you want to restore the default options for the Run Part Analysis window, click Restore and select Defaults.
  9. Click the Run button to start the analysis.
Tip:
  • If you select a part that is a member of a rigid group, the whole rigid group will be analyzed.
  • If you don't want to wait for the run to finish, you can close the Run Status window and continue working in Inspire. You can check on the status of a run at any time by clicking the Run Status tool on the Analyze Part icon.
  • There is no design space for an analysis, so there is no requirement to break up your model into design and non-design spaces and apply loads only to the latter. Any part can be analyzed. However, if you intend to optimize the part later, it is beneficial to split your part into design and non-design spaces and apply appropriate loads and supports prior to running a baseline analysis.
  • If you want to run reanalysis on an optimized shape, double-click it, then use the Analyze button on the Shape Explorer.
  • To export all loads acting on a part during the simulation, create any plot related to the part, right-click the plot, and then select Export Loads on Part. There's also an option to export the connection locations of all objects attached to the part.
