Usage Efficiency
This report illustrates how efficiently software is utilized. By analyzing unique peaks and total hours used, we can identify the distribution of where peaks occur most frequently.
Goal
An efficiency chart—particularly one with cumulative ascending data—can help determine the appropriate software license level based on the most concentrated usage hours or wall time. Look for steep ascents in the cumulative line, which indicate periods of high license utilization.
Figure 1. Usage Efficiency
The report details are as follows:
Table 1.
Name Description
Vendor Software
Feature Licensed feature
Peak Used Hours Total hours for the observed Peak
Cumulative Used Hours % Total hours the software is used over time (ascending as usage accumulates) in percent
Cumulative Wall time Hours % Total wall time hours the software is used over time (ascending as usage accumulates) in percent
Desc Used Hours % 100 - Cumulative Used Hours
Desc Wall time Hours % 100 - Cumulative Wall time Hours
