Soft Limit Analysis
This report analyzes whether the defined soft limit for a given software-licensed feature has been exceeded within the selected hierarchy.
- Goal
- In conjunction with the Administration Tool for Soft Limits, this report helps track how often a specific hierarchy exceeds its allotted peak usage over a given time period. While exceeding the soft limit does not block software usage, this insight can be valuable for future internal resource management and planning.
The report details are as follows:
| Name | Description |
| Hierarchy Node | Defined hierarchy child element for soft limit |
| Period | Period valid for soft limit definition |
| Soft Limit | Allotted soft limit value |
| Number of Times at/over Soft Limit | Number of times allowed peak exceeded allowed soft limit |
| Max Peak | Max concurrent usage |
| Average Peak | Average peak |
| Percentile Peak | Specific percentile peak of the data distribution |
