Feature Usage Summary By User
This report presents usage metrics KPIs for a given licensed software feature, segmented by users, such as peak usage (maximum, percentile, and average), peak duration, maximum and minimum number of concurrent checkouts, number of checkouts, denials encountered, total usage hours, average session lengths, etc.
Goal
To evaluate users’ software usage in terms of hours and number of checkouts, while also focusing on average session lengths to determine if users are appropriately checking out and checking in the software as needed. With the addition of peak (max, percentile, average), peak duration, and maximum/minimum concurrent checkouts, you can gain deeper insight into the users’ usage patterns and identify whether multiple concurrent license checkouts are causing denials for other users.
Figure 1. Feature Usage Summary by User
The report details are as follows:
Table 1.
Name Description
Vendor Software
Feature Licensed feature
Max Concurrent Runs Max number of simultaneous checkouts
Min Concurrent Runs Min number of simultaneous checkouts
Num Runs Number of NORMAL and BORROWED records
Num Denials Number of denials
Peak Max concurrent checkout license consumption
Percentile Peak Specific percentile peak of the data distribution
Average Peak Average peak
Peak Duration For the observed peak, how long the peak was for
Session Length Total hours of usage
Average Session Length Average hours of usage
