/SURF/MAT/ALL
Block Format Keyword Describes the material surfaces which belong to given materials.
Enter selected items numbers (any number may be input, 10 per format).
| /SURF/MAT/ALL/surf_ID/unit_ID | |||||||||
| surf_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| surf_ID | Surface
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| surf_title | Surface
title. (Character, maximum 100 characters) |
| item_ID1, item_ID2, ... item_IDn | List of material
identifiers. (Integer) |
- The format is the same as the corresponding options /SURF/type/surf_ID.
- For solid elements, a surface segment is created for
every face of a solid element that belongs to the item_ID
listed.
The segments built from 3-node and 4-node shells are still selected the same way as with /SURF/type/surf_ID.
