/SURF/SUBSET
Block Format Keyword Describes the subset surfaces which belong to given subsets.
Enter selected items numbers (any number may be input, 10 per format).
/SURF/SUBSET/surf_ID/unit_ID | |||||||||
surf_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
surf_ID | Surface
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
surf_title | Surface
item_ID1, item_ID2,... item_IDn | List of subset identifiers
4 (Integer) |
- All surface segments must belong to 2D elements (shell element or a triangular shell element). 1D elements are ignored in /SURF/SUBSET. With 3D elements, an additional keyword must be specified: see /SURF/SUBSET/EXT and /SURF/SUBSET/ALL
- A surface cannot be defined using Madymo surfaces.
- A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
- If item_ID is negative, the surface normals are inverted.
