/SURF/SEG
Block Format Keyword Describes the surface segments definition.
| /SURF/SEG/surf_ID/unit_ID | |||||||||
| surf_title | |||||||||
| seg_ID1 | node_ID1 | node_ID2 | node_ID3 | node_ID4 | |||||
| seg_ID2 | node_ID1 | node_ID2 | node_ID3 | node_ID4 | |||||
| etc | etc | etc | etc | etc | |||||
| seg_IDn | node_ID1 | node_ID2 | node_ID3 | node_ID4 | |||||
Format for 2D and axisymmetrical analysis
| seg_ID1 | node_ID1 | node_ID2 | |||||||
| seg_ID2 | node_ID1 | node_ID2 | |||||||
| etc | etc | etc | |||||||
Definition
| surf_ID | Surface
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| surf_title | Surface
| seg_ID1, seg_ID2, seg_IDn, | Segment identifier
(optional) (Integer) |
| node_ID1 | Node identifier
1 (Integer) |
| node_ID2 | Node identifier
2 (Integer) |
| node_ID3 | Node identifier
3 (Integer) |
| node_ID4 | Node identifier 4
(optional for triangular elements) (Integer) |
- Surfaces are used to define interfaces in 3D analysis and pressure loads.
- The node_ID4 may be omitted for triangular elements.
- Segments may be given by "cut and paste" of shell element input data.
- All nodes must belong to a shell element, a brick element or a triangular shell element.
- A surface cannot be defined using Madymo surfaces.
- A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
