/SURF/DSURF
Block Format Keyword Describes the surface definition. Has the same behavior as /SURF/SURF; except when a negative ID is used.
/SURF/DSURF/surf_ID/unit_ID | |||||||||
surf_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
surf_ID | Surface
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
surf_title | Surface
item_IDi | List of surface
identifiers If negative, the surface is removed. (Integer) |
- All nodes must belong to a shell element, a brick element or a triangular shell element.
- A surface cannot be defined using Madymo surfaces.
- A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
- Same option as
/SURF/SURF, except in case of negative ID is used.
/SURF/DSURF/3 Title 1 -2
Surface 3 = Surface 1 - Surface 2 (Surface 2 is removed)
