/SURF/PLANE
Block Format Keyword Describes an infinite PLANE surface defined by a normal vector MM1.
| /SURF/PLANE/surf_ID/unit_ID | |||||||||
| surf_title | |||||||||
| XM | YM | ZM | |||||||
| XM1 | YM1 | ZM1 | |||||||
Definition
| surf_ID | Surface
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| surf_title | Surface
| XM | X
coordinate of M (end of normal
vector) (Real) |
| YM | Y
vector) (Real) |
| ZM | Z
vector) (Real) |
| XM1 | X
coordinate of M1 (head of normal
vector) (Real) |
| YM1 | Y
vector) (Real) |
| ZM1 | Z
vector) (Real) |
- The infinite
PLANE is defined by a normal vector MM1 (M belongs to plane).
