/SURF/GRBRIC/FREE
Block Format Keyword Describes the free surface selection from 3D element group. Free surface is an external surface which is not connected to any other 3D element.
Enter selected items numbers (any number may be input, 10 per format).
| /SURF/GRBRIC/FREE/surf_ID/unit_ID | |||||||||
| surf_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| surf_ID | Surface identifier (Integer, maximum 10 digits) |
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| surf_title | Surface title (Character, maximum 100 characters) |
| item_ID1, item_ID2,... item_IDn | List of brick group
identifiers (Integer) |
- Free surface is external surface which is
- A surface cannot be defined using Madymo surfaces.
- A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
