*RIGIDWALL_GEOMETRIC
LS-DYNA Input Interface KeywordDefine a rigid wall with the different following shape.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *RIGIDWALL_GEOMETRIC_TYPE_{OPTION}_{OPTION}_{OPTION} | |||||||
| Rwall_ID | Title | ||||||
| Set_ID | Setex_ID | Box_ID | |||||
| XT | YT | ZT | XH | YH | ZH | FRIC |
| Radius |
| XHEV | YHEV | ZHEV | LENL | LENM |
| XHEV | YHEV | ZHEV | LENL | LENM | LENP |
| Fct_ID | OPT | VX | VY | VZ |
Definition
| TYPE |
| OPTION |
| Rwall_ID | Optional rigid wall identifier. (Integer)  |
| Title | Optional title. (Character, maximum 70 characters)  |
| Set_ID | Node set for the rigid wall contact. (Integer)  |
| Setex_ID | Node set to exclude from the rigid wall
| Box_ID | Box identifier for the rigid wall
| XT | Rigid wall tail point X coordinate. (Real)  |
| YT | Rigid wall tail point Y coordinate. (Real)  |
| ZT | Rigid wall tail point Z coordinate. (Real)  |
| XH | Rigid wall head point X coordinate (defining normal
                                        direction). (Real)  |
| YH | Rigid wall head point Y coordinate (defining normal
| ZH | Rigid wall head point Z coordinate (defining normal
| FRIC | Coulomb friction coefficient. (Real)  |
| Radius | Cylinder or sphere radius. (Real)  |
| XHEV | Rigid wall edge point X coordinate. (Real)  |
| YHEV | Rigid wall edge point Y coordinate. (Real)  |
| ZHEV | Rigid wall edge point Z coordinate. (Real)  |
| LENL | Rigid wall size on the 1st edge. (Real)  |
| LENM | Rigid wall size on the 2nd edge. (Real)  |
| LENP | Rigid wall size on the 3rd edge (in opposite as normal
| Fct_ID | Imposed motion function (velocity/displacement versus
                                        time). (Integer)  |
                                or |
| OPT | Imposed motion type.
| VX | Imposed motion direction X. (Real)  |
| VY | Imposed motion direction Y. (Real)  |
| VZ | Imposed motion direction Z. (Real)  |
