*CONSTRAINED_JOINT_STIFFNESS
LS-DYNA Input Interface KeywordDefine a stiffness, stop angles and friction for rotational DOFs of a joint between two rigid bodies.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONSTRAINED_JOINT_STIFFNESS_{OPTION} | |||||||
If OPTION = ID, insert the following line.
| Title | |||||||
If OPTION = GENERALIZED, insert the following
line.
| JSID | PIDA | PIDB | CIDA | CIDB | |||
| LCIDPH | LCIDTH | LCIDPS | LCIDDPH | LCIDDTH | LCIDDPS | ||
| ESPH | FMPH | ESTH | FMTH | ESPS | FMPS | ||
| NSAPH | PSAPH | NSATH | PSATH | NSAPS | PSAPS |
Definition
| OPTION |
| Title | Joint title. (Character, maximum 70 characters) |
| JSID | Joint ID. (Integer) |
| PIDA | Part ID for first rigid component. (Integer) |
| PIDB | Part ID for second rigid component. (Integer) |
| CIDA | Coordinate system for the first rigid
| CIDB | Coordinate system for the second rigid
| LCIDPH | Curve ID for moment versus angle in radians around PHI
axis. (Integer) |
| LCIDTH | Curve ID for moment versus angle in radians around THETA
axis. (Integer) |
| LCIDPS | Curve ID for moment versus angle in radians around PSI
axis. (Integer) |
| LCIDDPH | Curve ID for damping moment versus rotational velocity around
PHI axis. (Integer) |
| LCIDDTH | Curve ID for damping moment versus rotational velocity around
THETA axis. (Integer) |
| LCIDDPS | Curve ID for damping moment versus rotational velocity around
PSI axis. (Integer) |
| ESPH | Elastic stiffness for friction and stop angle around PHI
axis. (Integer) |
| FMPH |
(Integer) |
or None |
| ESTH | Elastic stiffness for friction and stop angle around THETA
axis. (Integer) |
| FMTH |
(Integer) |
or None |
| ESPS | Elastic stiffness for friction and stop angle around PSI
axis. (Integer) |
| FMPS |
(Integer) |
or None |
| NSAPH | Stop angle in negative PHI direction. (Real, positive) |
| PSAPH | Stop angle in positive PHI direction. (Real, positive) |
| NSATH | Stop angle in negative THETA direction. (Real, positive) |
| PSATH | Stop angle in positive THETA direction. (Real, positive) |
| NSAPS | Stop angle in negative PSI direction. (Real, positive) |
| PSAPS | Stop angle in positive PSI direction. (Real, positive) |
- This keyword maps to /SPRING, /PROP/TYPE45 (KJOINT2) and /PART.
- It works in combination with kinematic joint and determines stiffness, friction, and stop angles for rotational degrees of freedom for joints interconnecting rigid components, PIDA and PIDB.
