*CONSTRAINED_INTERPOLATION
LS-DYNA Input Interface KeywordDefines an RBE3 element.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONSTRAINED_INTERPOLATION_{OPTION} | |||||||
| ICID | DNID | DDOF | CIDD | ITYP |
If ITYP = 0, insert following lines for each
independent node.
| INID | IDOF | TWGHT |
If ITYP = 1, insert one lines for set of
independent nodes.
| ISNID | IDOF | TWGHT |
If OPTION = LOCAL, insert the following
line.
| CIDI | |||||||
Definition
| OPTION | Coordinate system option.
| ICID | Interpolation constraint element identifier.
(Integer) |
| DNID | Number of dependent node. (Integer) |
| DDOF | DOFs of dependent node. (Integer) |
| CIDD | Local coordinate system identifier for DOF definition of
dependent node. Only for LOCAL option. Global
system is used by default. (Integer) |
| ITYP | Input flag for independent nodes.
| INID | Independent node number. (Integer) |
| ISNID | Set number of independent nodes. (Integer) |
| IDOF | DOFs for independent node, or set of independent nodes. | |
| TWGHT | Weighting factor for independent node or for set of
independent nodes (same for all DOFs). (Integer) |
| CIDI | Local coordinate system identifier for DOF definition of
independent node. Only for LOCAL option. Global
system is used by default. Note: This value should be exactly
the same as
CIDD. (Integer) |
- This keyword maps to /RBE3.
