OS-E: 0155 Snap-Fit Analysis (CONSLI versus FINITE)
Snap-fit is a combination of two components namely mating and base part which form a mechanical attachment between them by means of locators, locks and enhancements. Nonlinear Static Analysis with large displacement theory is used to solve this example.
Figure 1. FE Model
Model Files
Model Description
- FE Model
- Element Types
- CTETRA
- MAT1 and MATS1
- Young’s Modulus
- 2700 MPa
- Poisson's Ratio
- 0.35
- Initial Density
- 1.04E-9 Mg/mm3
Stress versus Strain curve is defined with MATS1.
Results
Figure 2. Element Stress Contour
Concludes that the high stress concentration areas (Figure 2) are sensitive to the ramp-angle of the block, thickness of the flap and sharp corners. Such problem areas can be improved by means of notches, appropriate angles on the mating and base parts, respectively.
Figure 3. Finite Sliding versus Continuous Sliding
