OS-E: 0145 Nonlinear Analysis of Rack and Pinion using Restart
This example problem is of a rack and pinion mechanism, and showcases the restart capability available in OptiStruct.
Figure 1. FE Model
Model Files
Model Description
- FE Model
- Element Types
- CHEXA
- MAT1
- Young’s Modulus
- 2.1E5 MPa
- Poisson's Ratio
- 0.3
- Density
- 7.85E-9
Results
Figure 2. Displacement Contour
