Show, Hide, and Isolate Entities
Turn the display of entities on and off in the modeling window.
Show, Hide, and Isolate Using Context Menus
- Hide
- Hides selected entities.
- Hide All
- Hides all entities of the same type as the entity selector.
- Hide Model
- Hides the entire model.
- Hide All Off Screen
- Hides all entities located outside of the modeling window but in currently displayed collectors.
- Show
- Shows selected entities.
- Show All
- Shows all entities of the same type as the entity selector.
- Show Adjacent
- Shows the entities adjacent to your selection or all adjacent entities that are the same type as the entity selector.
- Show Model
- Shows the entire model.
- Show All On Screen
- Shows all entities located outside of the modeling window but in currently displayed collectors.
- Isolate
- Isolates selection and turns off the display of all other entities, regardless of type.
- Isolate Entity
- Works locally within a specific entity type; for example, if component(s) are isolated, then all display states of other entities, such as load collectors, are unaffected. Isolate Entity displays only the selected entities, and turns off all other entities of the same type.
- Isolate Displayed
- Isolates all entities of the same type as the entity selector.
- Reverse Displayed
- Reverses the display of the entity type in the entity selector. If the All filter is active it reverses the display of all the entity types.
- Reverse Selected
- Reverses the display of the selected entities.
- Unhide
- Unmasks all entities in the currently displayed collectors.
Show and Isolate Nearby Entities
Supported source entities: Nodes, elements, components, systems, vectors, loads, and equations.
Supported target entities: Elements, components, systems, vectors, loads, and equations.
Define settings for showing and isolating nearby entities.
- Select valid source entities.
In the modeling window, right-click and select from the context menu.
The target entities defined in the settings dialog are shown/isolated.
Show, Hide, and Isolate in Browsers Using Context Menus
Show and Hide in Browsers Using Icons
![](../../images/icons/icon_browser_geometry.png)
![](../../images/icons/icon_browser_mesh.png)
![](../../images/show_hide_browser_icons_hwx.png)
Show, Hide, and Isolate in the Modeling Window Using Context Menus
Show, Hide, and Isolate Using the Show/Hide Tool
- Activate the Show/Hide tool
on the View Controls toolbar.
- Select entities to show or hide.
HyperMesh and HyperView
- Activate or deactivate the check boxes in the microdialog.The microdialog lists the available entity types in your model that you can show/hide. A selected check box indicates that all of the entities of that type are displayed. A check box with a line indicates some of the entities of that type are displayed, but not all. An empty check box indicates that there are no entities of that type displayed.Tip: Click All/None/Only to quickly change the display state of multiple entity types.
Figure 3.
- Use the Show/Hide
guide bar for more precise control.
- Select an entity type using the entity selector.
- Click
to define the following options.
- Furthest to closest
- When showing hidden entities, pick from furthest to closest in depth. Turning off this option will pick closest first.
- Sync with Browser
- Sync selection with browser.
- Left-click entities to hide them,
Shift + left-click to show them, or use
of the show/hide icons on the guide bar.
- Show all of the current entity type.
- Show none of the current entity type.
- Reverse the display of the current entity type.
- Isolate selection only or all of the current entity type.
HyperGraph
Left-click entities to hide them, Shift + left-click to show them, or use of the show/hide icons on the guide bar.
MotionView
Left-click entities to hide them or use of the show/hide icons on the guide bar.
MediaView
Simply activate or deactivate displayed entity types.
Keyboard Shortcuts and Mouse Controls
HyperMesh
To do this | Press |
Enter and exit the Show/Hide tool | D |
Show selection If there is no selection, show all of the current entity type |
A |
Show entire model | Shift + A |
Hide selection If there is no selection, hide all of the current entity type |
H |
Hide and clear selection (Idle mode only) |
Ctrl + H |
Isolate selection and turn off all other entity types If there is no selection, isolate the current entity type |
I |
Isolate selection and retain all other entity types (Show/Hide tool only) |
Shift + I Middle Mouse Click Tip: Middle mouse click again to reverse the isolated
display. This is useful if you want to append to your
selection and isolate more entities. |
Show entities adjacent to selection If there is no selection, show adjacent entities that are the same type as the entity selector (Idle mode only) |
J |
Reverse display of selection If there is no selection, reverse the display of the current entity type |
R |
Switch the display from mesh only, geometry only, or both (Idle mode only) |
G |
Toggle on/off IDs of a selection (Idle mode only) |
Q |
HyperView
Show all | A |
Hide selection | H |
Isolate selection | I Middle Mouse Click (Show/Hide tool only) |
Reverse display | R |
Show adjacent entities to selection | J |
Show none (Show/Hide tool only) | N |
HyperGraph
Show all | A |
Isolate selection | I |
MotionView
Show all | A |
Reverse selection | Ctrl + R |
