Change Geometry and Mesh Display Settings
Change the visual display of geometry and meshing in the modeling window.
HyperMesh
From the View Controls toolbar, click
- Shaded geometry - Display shaded geometry with or without surface edges.
 - Geometry transparency - Set geometry transparency to 25%, 50%, or 75%.
 - Wireframe geometry - Display wireframe geometry with or without surface lines.
 - Do not draw geometry (G) - Hides geometry in the modeling window and is independent of an entity's saved visibility state.
 - Shaded elements - Display shaded elements with mesh lines, only feature lines, or no mesh lines.
 - Mesh transparency - Make mesh transparent.
 - Wireframe elements - Display wireframe elements with or without internal mesh lines.
 - Do not draw mesh (G) - Hides elements in the modeling window and is independent of an entity's saved visibility state.
 - Display associated geometry/FE - Display the associated geometry/FE on show/hide/isolate.
In addition to global geometry and mesh display settings, you can also change the visualization style of select components using the Geometry and Mesh Visualization tool.
- Open the Geometry and Mesh Visualization tool in the following ways:
- Click
 on the View Controls toolbar. - Press X.
 - Click
 - Click the drop-down besides the options menu to toggle geom and mesh display.
 - Select a visualization style and the components on which to apply it.
- Mesh
 - Wireframe elements skin
                                        only- Geometry
 - Wireframe geometry- Geometry Transparency
 - Apply selected
                                        transparency
Applying a visualization style to a component adds it to the selection. If you change the style, it applies to all selected components.
If a component doesn't have any elements associated with it, you will not be able to select that component when changing the mesh visualization.
HyperView
 - Surface transparency. Turn elements transparent.
MotionView
- Opaque
 - Translucent
 - Transparent
