Use the Orientation Review tool to display/review and modify frequently used
coordinate systems used in CAE analysis.
Review Elemental Systems
Select 1D, 2D, or 3D elements and display the coordinate system.
Elemental systems are dependent on the solver type. For example, for Nastran and for quad elements the X axis is determined using
the bisector of the diagonal line.
From the 2D ribbon, click the Orientation Review tool.
The Orientation Review dialog opens.
Click the Elemental system tab.
Use the Elements selector to select elements.
Define display options.
Click Apply to show the
system display.
The mode element can be added and the display can
be super imposed. Clicking Clear removes the information that you
added, and clicking Clear All removes the system.
Review Material Systems
Figure 3.
Click the Material system tab.
system display.
By default the material system aligns with the C1 direction of the element edge. C1
is the direction from node 1 to node 2 of the element. You can super impose the
elemental system on the same plot of the material system.
Figure 4. . The blue and green arrows represent the elemental system (x and y) and the
red and brown arrows represent the material system (x and y).
Review Ply Directions
During CAD import of the composite data, each ply is associated with one or a
separate system (one system for several plies or a system for each ply). You can select a
ply and review its system.
This is important to
align the element normal to match the ply normal, or correct the ply angles if the
normals are in the opposite direction.
Figure 5.
Click the Ply Directions tab.
Use the ply selector to select plies.
Define ply options.
To show fiber direction without the correction for drape, select the
Fiber orientation checkbox.
To show fiber direction with drape correction, select the
Drape fiber orientation checkbox.
To show a ply system for each ply, select the
System checkbox.
Click Apply to show the ply
system.
Figure 6. . The green arrows show the material X direction. The blue arrow shows the
ply 5 fiber direction without drape. The red arrows shows ply 5 fiber
direction with drape.
Review Orientation
Display and correct element orientation.
Element orientation is
determined by the order of the nodes in the element connectivity. This is sometimes
referred to as C1, C2, C3, or element local system.
Figure 7.
Click the Orientation tab.
Use the elements selector to select elements.
Select a function.
Choose By element to select an element with the
correct orientation.
Choose By edge_node to select edge nodes with the
correct direction.
Choose By System to select a system with the
correct 1, 2, 3 direction.
Choose Vector to select a vector
direction.
Choose Align N1-N2 dir to select a selection
method.
The orientation of the rest of the elements will be determined based on the
orientation or direction of the selected entity.
Figure 8. Display Normal and Reverse Normal 2D Elements.
Figure 9. Reverse Normals. The element already selected during the display normal will be
reversed.
Figure 10. C1, C2, C3 Direction. This displays the element orientation of the nodes. C1 is the direction
from node 1 to node 2 using the element connectivity order.
Figure 11. Resequence Nodes. Align C1 direction of 2D quad elements. Using the display C1 direction,
some of the elements may not be aligned, as shown in the previous image.
Select a guide element as the reference element and the rest of the element
node connectivity will be changed to align the C1 direction.
Figure 12. Reverse 1D Element Direction. T function reverses the X direction (node 1 to node 2) of a 1D element.
This image shows before reversing the elements.
Figure 13. After Reversing Elements
Review Ply Normals
Indicate which ply angles need to be reversed for which elements when they do not
match the ply normal.
CAD based ply angles and orientation are transformed with respect to the element
material system for analysis solvers. Most of the time you can correct the element
normal to match the ply normal from the CAD. There are times when it is not possible
to change the element normal to match the ply normal, as shown in the diagram below.
In these cases, you need to change the ply angles with respect to the element normal
without changing the element normal. For example, a +45 degree ply will become a -45
degree ply if the element normal and ply normal are in opposite directions.
Figure 14.
Figure 15. . The ply normal does not match the element normal.
Figure 16.
Click the Ply Normals tab.
Use the ply selector to select the single ply for which the element normal
needs to be reversed.
Use the Elements selector to select the elements that need to be
reversed.
Under Normals, specify how to display normal.
Choose Display to display normals.
Choose Reverse to reverse the display of the
normal if they do not match.
normals.
Repeat these steps for each ply.
The element normal for the ply is now reversed.
Note: The actual element
normal is not changed. The software takes a note (sets a flag internally)
for a particular ply, and the angle needs to be reversed for that element,
instead of reversing the normal. This is reflected in the solver
data.
