2026
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
Create an assembly structure from a .csv file definition.
Use the Coordinates Precision Control tool to control the node precision in the Nastran/OptiStruct output decks (GRID) card.
Round off the node coordinates (multiple nodes) to the desired precision and update the HyperMesh database.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
