2026
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
Create an assembly structure from a .csv file definition.
Use the Quick Coord Creation tool to create a system using beam or shell elements.
Use the System-Node Review tool to find the nodes that have a local reference system or analysis system attached.
Allows you to have the same system defined in both HyperMesh and HyperView.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
