Create Regions from Metadata to CAE
Create regions from points, lines and surfaces with metadata.
                In the Mesh Controls Browser, right-click on the
                        Region folder and select  from the context menu.
                The Metadata to CAE dialog opens.
 - Set Create to Regions.
 - Set From to Points, Lines or Surfaces.
                In the Metadata field, select a specific metadata name.
                A list of entities is generated.
 - In the table, select entities from which to create regions.
 - Click Apply.
