BatchMesher Mesh Controls
Model and local mesh controls for BatchMesh meshing.
When generating the mesh, local controls are applied first, starting from the smallest target element size, up to the largest. The model control is then applied.
Normal Parameter Mode
Parameter | Description |
Criteria File | Specify a criteria file that will be used to automatically generate criteria. |
Parameters File | Specify a parameters file that will be used to automatically generate criteria. |
Mesh Connectivity | Determines how newly created elements and any adjacent
existing elements are connected.
Scaled Parameter Mode
Element Size | Element size used when scaling criteria and parameters. |
generate criteria. The "min size" and "max size" thresholds are created by simple proportional scaling of the base thresholds to the requested element size. All other criteria is not changed. |
generate criteria. All dimensionless parameters and options are not changed. All parameters having a length
dimension are proportionally scaled using the scale factor
target size/original size.
Auto Generate Parameter Mode
The Auto Generate parameter mode generates criteria and parameters on-the-fly using very basic and limited input parameters. This parameter mode is useful for basic and simple use cases, where existing parameter and criteria files do not exist and you do not have strict mesh requirements.
Mesh Control Input Parameter | Criteria File Field |
Element Size |
Minimum Element Size | Min Size - Fail |
Maximum Element Size | Max Size - Fail |
Mesh Control Field | Parameter File Field |
Element Size | Target element size |
Element Type | Create mesh with element type, with “align” and “size” checkboxes enabled. |
Element Order | Element order |
Element Feature Angle | Feature angle during element cleanup |
Geometry Cleanup | Enables or disables, in its entirety, the Geometry cleanup section |
- min_rad = max(0.4*Element Size, 0.8*Minimum Element Size)
- mid_rad = max(0.6*Element Size, min_rad)
- max_rad = 3.0*Element Size
- Remove Small Holes
- Removes small surface and solid holes with a radii range of 0 – min_rad.
- Create Washers
- Create one layer of washers with a minimum of 6 elements and an auto-defined width for surface holes in the min_rad – max_rad range.
- Seed Holes
- Enable hole seeding for surface and solid holes, per the rules below. If
Create Washers is enabled, this is ignored for surface holes.
- min_rad – mid_rad = 4 elements minimum
- mid_rad – max_rad = 6 elements minimum
- Allow Movement Across Edges
- Enable major post-mesh element cleanup operations to improve the final element quality at the expense of edge capturing and performance.
- Advanced Feature Capture
- Enable improved feature capturing at the expense of element quality and performance.
- Extract midsurfaces is enabled with the Method set to skin offset.
- Geometry Cleanup
- Surface fillet recognitionThe following thresholds are defined:
- min_rad = 0.7*max(0.4*Element Size, Minimum Element Size)
- min_wid = 0.49*Pi*min_rad
- mid_rad = 1.307*max(0.5*Element Size, Minimum Element Size)
- mid_wid = 0.5*Pi*mid_rad
- max_rad = 1.5*Element Size
- max_wid = 0.51*Pi*max_rad
The following number of elements rows are enforced:- min_rad – mid_rad and min_wid – mid_wid = 1 element across
- mid_rad – max_rad and mid_wid – max_wid = 2 elements across
- Flange recognition is enabled with:
- Elements across flange width = 2
- Maximum width of flange = 3.5*Element Size
- Minimum width of flange = max(0.5*Element Size, Minimum Element Size)
- Delete flange narrow surfaces with width < = auto
- Other options
- Suppress beads with height < = min( 0.2*Element Size, Minimum Element Size)
- Suppress flanged holes with height < = min(0.15*Element Size, Minimum Element Size)
- Remove edge fillets with radius < = 0.9*Element Size
- Remove logo with size < = 3.0*Element Size, and height < = min(0.15*Element Size, Minimum Element Size)
- Element Cleanup
- Apply tria reduction with min elem size > = 0.5*Element Size and max size < 1.5*Element Size
- Move across free edges, max dist < = 0.0025 * element size
