Import Geometry
The steps below outline how to import a CAD file.
- Select the System/Assembly/Analysis into which the geometry is to be imported (the Model system is the default).
- From the File menu, select .
- Select the importing CAD file using the File selector.
Click Open.
The CAD file is imported. A body and a corresponding graphic is created for each component in the CAD Part/Assembly.Note: Steel is the default material assigned to the graphics. To change materials, select the graphics in the modeling window and select Material using the right-click context menu.
