Flexbody solved in MotionSolve
To view the animation of flexible body results generated using MotionSolve, the result H3D file must be loaded in HyperView:
  1. From the Select application menu, select HyperView.
  2. From the Home tools, Files tool group, click the Open Model tool.
    OR
    From the File menu select Open > Model.
    See Open Files for additional information.
  3. From the Load Model panel, verify that the Load model and Load results check boxes are activated.
  4. Click the Load model file browser .
    The Load Model File dialog is displayed.
  5. Open the .h3d result file.
    The same file is automatically loaded into the Load results field.
  6. Click Apply.
