Add a Note to a Plot Macro
  1. From the Math Macro dialog, select a macro from the Macro List.
  2. Click Edit.
  3. Select the Note tab.
  4. Activate the Create note check box.
  5. Enter text in the Text box.
  6. Select Window, View, Existing curve, Coordinate, or Curve created by this macro from the Attach To combo box.
  7. Enter the data pertaining to the following:
    Existing curve
    Curve and point to which the note is attached.
    Coordinate
    X and Y coordinates to which the note is attached.
    Point to which the note is attached.
  8. Enter X and Y coordinates to position the note center.
    If you are plotting complex data, select Real/Imaginary or Phase/Magnitude for the Y coordinate. You can use the functions from the Functions list.
  9. Click Close.
