Datum Lines View
The Datum Lines View, , displays only the datum lines in
the session, grouped within their respective page and plot folders. Clicking on a
datum line displays the datum line's properties in the Entity Editor.
![](../../images/hypergraph/plot_browser_datumline_view_hgx.png)
When a datum line is selected, the following fields are displayed in the Entity Editor:
Standard
- Name
- The datum line name, created when you add a datum line.
- Label
- The datum line label.
- Visibility
- Click the check box to display the datum line in the modeling window.
- Layer
- The layer ID.
- Position
- Enter a value in the Position field.
- Associated Axis
- The axis the datum line is associated with.
- Type
- Horizontal or vertical datum line.
Display
- Font Settings
- Define the font type, style, and size.
- Label Location
- Select the location for the datum label in the modeling window.
- Line Style, Line Thickness, and Line Color
- Set the datum line attributes for line style, thickness, and color.
