Add a Note
Add a note to a point on a curve.
                From the Line Chart, Bar Chart, or Complex Chart ribbon, click the
                        Notes tool.
                Hover over the curve to locate the coordinates to add the note to. Once the
                    point value is displayed, left-click to add the note to the curve.
                Add a note to the window by clicking anywhere in the plot window. The note is displayed as View Note in this instance.
- To edit a note, double-click on a note to display the Edit Note dialog. Use this to edit the note's properties.
                From the Edit Note dialog, click  to display the Entity Editor. to display the Entity Editor.Figure 2. Entity Editor - Notes  Tip: You can also use the Plot Browser to edit the note. Click on the note from the plot window to display its attributes in the Plot Browser.Tip: See Notes for more information on editing the note attributes. Tip: You can also use the Plot Browser to edit the note. Click on the note from the plot window to display its attributes in the Plot Browser.Tip: See Notes for more information on editing the note attributes.
