UGS_LICENSE_SERVER
Specifies the UG license server to use for versions 8.5 and earlier.
UGS_LICENSE_SERVER value
Specifies the UG license server to use for importing UG files. This is required when
using UG versions 8.5 and earlier.
- value
- The proper value to point to the license server for your system.
Examples
UG license server located at port 28000 of licsrv: UGS_LICENSE_SERVER 28000@licsrv.
None.
