HM_TIMING
Creates a file that contains HyperMesh startup timing information.
HM_TIMING filename
                information. This information can be used for resolving startup time issues.
        - filename
 - The name and path to the file to use.
Examples
To create the file E:\temp\timing.txt: HM_TIMING E:\temp\timing.txt.
None.
