UGII_BASE_DIR
Specifies the path to the UG installation directory for importing UG files.
UGII_BASE_DIR directory
Specifies the path to the UG installation directory for importing UG files. This must
be used in conjunction with UGII_ROOT_DIR.
- directory
- The path to the UG installation directory. There should NOT be a '/' at the end of the UGII_BASE_DIR path.
Examples
UG installation located at /soft/usr/ugs090: UGII_BASE_DIR /soft/usr/ugs090.
UG installation located at C:\Program Files\Siemens\NX 9.0: UGII_BASE_DIR C:\Program Files\Siemens\NX 9.0.
None.
