2026
Create 2D sketches, surfaces, and solids.
Sketch and edit slots.
Discover new features and enhancements in Inspire Form.
New to Inspire Form? Learn the basics here.
Start using Inspire Form with our interactive tutorials.
Create and assign variables to parametrize a model. This allows you to quickly iterate and compare design concepts by tweaking the values of the variables.
View and edit the construction history of your model.
Global references are the global origin, axes, and planes shown in the modeling window. They can be helpful when creating and defining your model.
Learn about sketching basics including the sketch plane, legend, constraints, context menu options, and construction geometry.
Start a new sketch (S) and select a sketch plane.
Project selected geometry onto the sketch plane as construction geometry.
Extract curves resulting from the intersection of the sketch plane with selected parts or surfaces.
Sketch and edit a point, line, polyline (L), or line-arc.
Sketch and edit a rectangle (R).
Sketch and edit a parallelogram or a regular polygon.
Sketch and edit a circle (C).
Sketch and edit an ellipse or an elliptical arc.
Sketch a slot by defining the start and end points, mid and end points, arc center and end points, or three arc points.
Reposition, resize, or apply a sketch constraint to a slot.
Sketch and edit an arc (A).
Sketch and edit a spline (S).
Use the Dimension tool (D) to define and/or constrain the dimensions of a sketch.
Create an image plane that you can use as a background reference image, so you can trace lines and curves to start your design.
Translate or rotate sketch entities.
Trim (B) or split a sketch curve.
Extend or shorten an entity of a sketch curve.
Round the corners of 2D sketch curves to create fillets (F) with the same radius or different radii.
Offset (O) or mirror (M) a sketch curve.
Create a linear or circular pattern of sketch entities.
Export the current sketch as a .dxf or .dwg file.
Break sketch constraints or relationships to other features.
Create and modify parametric surfaces and solids.
Perform Feasibility, Blank Fit, and Blank Nesting analyses.
Use the Die Design ribbon to design and generate die surfaces.
Perform tryout analyses to validate die designs.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
Adjust the materials, environment, and properties of objects in the scene to create a photorealistic image.
Analyze the object geometry for negative draft, trim angle, and shortest distance between parts.
View the glossary or frequently asked questions.
Learn keyboard shortcuts and mouse controls for common operations.
