Export DXF/DWG
Export the current sketch as a .dxf or .dwg file.
                Double-click a sketch entity to enter sketch edit mode.
                Tip: You can also right-click a sketch and choose Edit or double-click a sketch in the Model Browser or History Browser to enter sketch edit mode.
                On the Sketching ribbon, select the Export DXF/DWG
                        icon.
 Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
- In the dialog box, select a folder, name your file, choose between .dxf or .dwg, and then click Save.
