Transform
Translate or rotate sketch entities.
                On the Sketch ribbon, select the
                        Transform tool.
 Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
                Select the sketch entities to translate or rotate.
                Note: Use box selection to select multiple sketch entities.
                Drag the relevant handle to translate/rotate the selected sketch
                    entities.
                Tip: To reposition the tool, double-click the handle or hold down Shift while clicking it.To temporarily disable snaps, hold down Alt while clicking. To Do this Note Translate horizontally - Drag the T handle.
- Select the T handle, and then enter the Horizontal distance.
 To maintain or break relations between sketch entities after translation/rotation, select  or or . .To restore the original position, select  . .Translate vertically - Drag the V handle.
- Select the V handle, and then enter the Vertical distance.
 Rotate - Drag the curved handle.
- Select the curved handle, and then enter an Angle.
