Trim/Break
Trim (B) or split a sketch curve.
Trim
Remove one or more entities of a sketch curve.
On the Sketch ribbon, select the Trim tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. -
Do one of the following:
- Select the entity you want to remove.
- Click-and-drag to draw a free-form line through the entities you want to remove.
Tip: If you remove an entity from the middle of a
line, the collinear constraint is automatically applied to the remaining entities of
the line. If you remove an entity from the middle of an arc, the concentric
constraint is automatically applied to the remaining entities of the arc.
Break
Divide an entity of a sketch curve at a selected point.
On the Sketch ribbon, select the Split tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Click an entity to select it.
Hover the mouse over the entity to preview the division point, and then click
to place the division point.
Note: It will automatically snap to intersection points, even if snapping to intersections is disabled.
