Edit a Slot
Reposition, resize, or apply a sketch constraint to a slot.
  1. Edit the slot:
    To Do this
    Reposition a slot
    • Select the line and drag it, or
    • Reposition the end points.
    Adjust the length of a slot
    • Drag the point if there is no dimension, or
    • Select the line, then enter a dimension to specify the length.
    Adjust the width of a slot Select the end curve and then enter a dimension to specify the width, or drag the arc end point if there is no dimension for the width.
    Change the diameter Select the sketch curve, then enter a radius.
    Apply a sketch constraint Right-click a sketch curve, then select a sketch constraint on the context menu.
    Convert a sketch curve into construction geometry Right-click a sketch curve, then select Construction.
    Construction geometry is used as a reference to line up or define other geometry.
    Hide dimensions Deselect Show dimensions in the Preferences.
  2. Right-click and mouse through the check mark to exit, or double-right-click.
