Transformation: definition (structure)
Definition
A transformation is defined by:
  • a name (and a comment)
  • a type
  • specific characteristics belonging to a type
Name
The name to identify the transformation is set by the user during the creation of this one.
A comment (optional) can be added to the name.
Types of transformation
The different types of transformations and the characteristics useful for their description are gathered in the table below:
2D domain
Translation defined by Description
a vector Coordinate system for definition
Vector components (DX, DY, (DZ))
2 points and a ratio
Points defining the vector (vector tail and vector head)
Ratio
2D domain
Rotation defined by
an angle and pivot point coordinates Coordinate system for definition Coordinates of the pivot point Rotation angle about Z-axis
an angle and existing pivot point Coordinate system for definition Pivot point Rotation angle about Z-axis
2D Domain
Symmetry with respect to Description
a point Center point of the symmetry
a line defined by two points
Points for definition of symmetry (1st and 2nd points of the straight line)
2D domain
Affine transformation with respect to Description
a point Center point of the affinity Scaling factor
Points for definition of affinity line (1st and 2nd points of the straight line)
Scaling factor
2D domain
Transformation Description
combining two transformations Two transformations defined beforehand
