Variable resistivity: spline approximation
Presentation
This model defines a conductive isotropic material by its resistivity (variable resistivity). The non linear J(E) electric behavior law is defined from pairs of experimental J, E values.
Mathematical model
The model is constructed in the following manner:
- entry of experimental J, E values
- interpolation by a spline function
The shape of the J(E) curve is given in the figure below.
Anisotropic material
This model is not available for an anisotropic material.
