Transient Magnetic volume (3D) / face (2D) region
Introduction
The volume (in 3D) / face (in 2D) regions are the material regions used to model the massive regions in the study domain.
Material regions (massive regions)
Material massive regions enable the modeling of the material media (with materials). The physical properties of the medium are those of the corresponding material region.
A massive region … enables the modeling … It is defined by …
air or vacuum of the air or of the vacuum
(predefined) (permeability μr = 1)
magnetic non conducting
of a medium: magnetic non-conducting
a material with: permeability μr
solid conductor
of a medium: magnetic conducting
resistivity ρ
coil conductor
of a medium: conducting with source
non-magnetic
→ this medium represents a coil:
  • constituted of a number of turns
  • passed through by current
a number of turns an electric component
laminated magnetic non conducting
of a laminated medium: magnetic (permeability μr) non conducting
→ this medium represents a stacked magnetic sheets:
  • plane (2D plane / 3D) or cylindrical (3D)
  • simplified via a homogenization technique
a material with: permeability μr a thickness of sheet iron a stacking factor
Specific to 2D and 3D with current density
of a medium: conducting with source non-magnetic
the value of the current density: (total value or spatial formula)
