Modify a solved scenario
Introduction
It is possible (under certain conditions) to modify a solving scenario that has been solved and to resume the solving process.
Conditions for modification
The conditions to modify a scenario are presented below.
For each parameter defining the control of the solving process it is possible:
  • to modify or delete the last interval
    (except for the 1st interval that defines the scenario)
  • to add one interval to the interval list
It is not possible to add a parameter to the list of parameters defining the control of the solving process.
Modify a scenario
To modify a solved scenario, follow the steps below:
Step Action
1 Edit the scenario to be modified
2 Choose the parameter whose control is to be modified
3
In the Parameter control zone :
to … then …
  • in the Intervals table zone
    click on Clear last interval
modify the last interval
    go to the last interval
  • in the Interval definition zone
    redefine the higher limit and the variation method
  • in the middle zone
    click on >>
add an interval go to step 5
4 Click on Yes in the confirmation box
5
to … then …
add an interval
    define a new higher limit and a variation method
  • click on >>
6 Click on OK to close the box
→ There is a possible deletion of results associated with the modified or deleted interval
Resume the solving process
To resume the solving process of a modified scenario, follow the next steps:
Step Action
1
In the Solving menu
  • point on Continue the solving process
    and click on Continue the solving process of a scenario …
2
In the box for the selection of scenarios
  • choose a scenario
→ Sequential solving of all the steps added to the scenario
