Isotropic / anisotropic materials
Introduction
The studied materials can be isotropic or anisotropic. In other words, the magnetic behavior of the material is as follows:
  • independent of the direction of the applied field (isotropic material)
  • dependent on the direction of the applied field (anisotropic material)
These two cases are presented in the following sections.
Isotropic materials
Isotropic materials are characterized by a law independent of the direction of the applied field.
The and vectors are always collinear.
The dependence between and is a scalar relationship, which is written as: D= ε .E
Anisotropic materials
Anisotropic materials are characterized by a law, which is dependent on the direction of the applied field.
The and vectors are not collinear.
The dependence between and is a vector relationship, which is written as:
with ε permittivity tensor:
… in Flux
The model provided in Flux is a simplified model.
The vector dependence between and which is written as: can therefore be expressed in the form of three curves: Dx(Ex), Dy(Ey), Dz(Ez)
The permittivity tensor is then written:
