Quantity and unit manager: creation and deletion
Introduction
Starting from the unit manager the user can:
  • Add one measurement unit to a usual quantity, if the desired measurement unit does not appear in the proposed list of units
  • Delete an added measurement unit
  • Add a personalized quantity (user quantity), if the desired quantity does not exist in the list of proposed usual quantities.
  • Delete a user quantity
Characterization of a measurement unit
A measurement unit is characterized by several fields:
  • Unit: corresponds to the abbreviation of the measurement unit
  • Factor: corresponds to the factor to apply to the reference measurement unit to retrieve the current measurement unit (example : 0.001 for the passage from T to mT)
  • Offset: corresponds to the value to add to the reference measurement unit to retrieve the current measurement unit (example 273.15 for the passage from °C to Kelvin)
  • Active: permits to check the measurement unit to be taken into consideration from a list of units for a usual quantity
  • Example: given an example of conversion between the reference measurement unit and the corresponding measurement unit and visa versa.
    It allows checking if introduced coefficients are exacts.
    (example: 1 kA = 1000 A and 1 A = 0.001 kA)
Note: * Reference measurement unit: corresponds to the measurement unit taken into consideration in Flux by default. In the manager it necessarily corresponds to the 1 st measurement unit available in the list of units of a given quantity.
Characterization of a user quantity
A user quantity is characterized by several fields:
  • Name: corresponds to the name of the quantity which will be used in Flux
  • Flux Formula: corresponds to the Flux formula associated to the user quantity (example Mod(B) for the module of B)
  • Title: corresponds to the tool type that will appear in Flux by pointing on the user quantity (example : module of magnetic flux density)
  • Symbol of the measurement unit: corresponds to the symbol of the measurement unit which will appear during the analysis of this user quantity (example: TESLA)
Add a measurement unit
To add a measurement unit in a proposed usual quantity:
Step Action
1 Open the Quantity and unit manager
→ The manager of units and quantities is open
2 Select the desired usual quantity in the proposed list at the left (tab Usual quantities )
→ The list of units corresponding to this quantity will appear at the right
3 Click on to add a measurement unit
The following window will appear:
4 Enter the abbreviation of the new measurement unit to be added
5 Validate by clicking on OK
The new measurement unit is added to the list of units proposed for the quantity selected by default:
  • A conversion factor to 1
  • An offset to 0
6
Modify the conversion factor to apply (if necessary) :
  • double click on the box
  • select the desired value
  • validate by Enter
The conversion factor is modified
The example given in the last column has been modified
7
Modify the offset to be applied (if necessary)
  • validate by Enter
8 Save the modifications carried out in the current dictionary by clicking on Save
The new measurement unit is ready to be used.
The dictionary CurrentUnitiesQty.dico was modified (or created if it did not exist) in the directory: C:\Program Files\Altair\2018.0\Flux_2018.0\Resources\UnityQty
Delete a measurement unit
To delete an added measurement unit :
Step Action
→ The manager of quantities and units is open
2 Select the quantity which contains the measurement unit to be deleted
3 Select the measurement unit to be deleted
4 Click on to delete the selected measurement unit
→ The measurement unit will disappear from the list of available units
5 Save the modifications carried out in the current dictionary by clicking on Save
→ The dictionary CurrentUnitiesQty.dico was modified in the directory: C:\Program Files\Altair\2018.0\Flux_2018.0\Resources\UnityQty
The units proposed by default cannot be deleted, only the units added by the user can be deleted.
Add user quantities
To add a user quantity:
Step Action
1 Open the Manager of quantities and units
2 Activate the tab User-defined quantity
→ The list of user quantities will appear (the list is empty if the user has never created personalized quantities)
3 Click on to add a quantity
4 Enter the name of the new quantity to be added
→ The new quantity has been added to the list of user quantities with by default in the fields « Name », « Flux Formula » and « Title » the name entered during step 4
6
Modify the Flux formula to apply:
  • capture the Flux formula associated with the new quantity
  • validate by Enter
→ The Flux formula associated to the quantity is modified
7
Modify the title to apply as a tool type:
  • capture the desired title
  • validate by Enter
→ The title has been modified.
8
Choose the symbol of the measurement unit to apply:
  • capture the desired symbol of the measurement unit
  • validate by Enter
→ The symbol of measurement unit associated with the size is displayed
9 Save the modifications carried out in the current dictionary by clicking on Save
The new quantity is ready to be used and it will be available in the list of quantities at the moment of computation in the results of the project (curve, calculation on a point, isovalues, arrows …).
To delete a user quantity:
Step Action
2 Activate the tab User quantities
3 Select the quantity to delete
4 Click on to delete the selected user quantity
→ The quantity will disappear from the list of user quantities
The usual quantities cannot be deleted, only the quantities added by the user can be deleted.
