Link regions and components: coil conductor
To link the regions of the coil conductor type (of the FE domain) to the components of the stranded coil conductor type (of the electric circuit), follow the next procedure:
Step Action
1
In the Physics menu:
  • point on Assign coil conductor components to regions and click on Assign coil conductor components to face regions
→ Division of graphic zone in two and visualization of FE domain in one zone and the electric circuit in the other
Display of the face regions of coil conductor type in the form of array
2
In the array*, fill out the zones for each region:
  • Electric component (of stranded coil type)
  • Current orientation (positive or negative)
Note: * See figure below.
Array of coil conductors
The array corresponding to the regions of the coil conductor type (2D) is presented in the figure below.
In this array, the zones which allow the visualization of the regions (of coil conductor type) and of the electric components (of stranded coil conductor type) are showed in the figure below.
